Wide MAF Voltage/AFR Spread
Hey there!
I have a Mazda RX-8 6-port that runs well but I've had some AFR stability issues for a while. To make a long story short, I decided to check my MAF calibration, so I re-flashed my ECU so that closed-loop never kicks in, set all my compensation tables to be flat, and logged some data.
What I found was weirder than I was expecting. The image I attached shows a scatter plot of AFR readings against MAF voltage. It looks like I'm getting a variation of about .1 lambda at every voltage reading!
I'm guessing at this point, it's a mechanical issue that needs to be sorted out? Injectors maybe? Any input would be greatly appreciated.
I also attached the log file that graph was generated from.
Thanks!
Bryan
Hello this could be caused by a few things but i would start as you have also pointed out the injectors may need a service, fuel filters, pump flow and prssure also check the maf calibration file.
Regards Ross
Thanks!
