Camshaft degrees
How to Degree a Cam
Hi,
Must we adjust to cams from cam specs?
For more performance? Or is the another adjustment?
It's always advisable to start out with the cam degreed to the manufacturer's recommendations. Often we will then try moving the cam while on the dyno to see if there is any more power to be had or if we can optimise the power curve to suit our requirements better.
