Degreeing HKS camshafts
How to Degree a Cam
Hi Andre , I bought a pair of used HKS camshafts for the RB26DETT , unfortunately I didn't receive any cam card . The both cams are Step 1 256 deg with 9.0mm lift.
The only info I found online (HKS website) is : IN 256 deg valve timing 110 deg
EX 256 deg valve timing 113 deg
How do I use this info to degree the camshafts ?
Thanks in advance.
I believe they use the OEM timing, if you have a manual for the engine, does it have a timing procedure? Failing other info', I'd set it to the OEM.
