Degreeing VVT cams - VQ35DE
How to Degree a Cam
Hi there,
I would like to ask about the considerations and process to adjusting and degreeing camshafts with VVT sprockets.
I am currently in the process of timing my VQ35DE which has been fitted with grounded oem camshafts. The machinest has specified particular valve lift at TDC for both intake and exhaust. Do I need to set timing with the sprocket fully retarted?
Your time is greatly appreciated!
David
