Piston Stop and Side firing spark plug
How to Degree a Cam
Can i use the bolted piston stop in a side firing spark plug engine?
I assume you mean a combustion chamber where the spark plug is screwed in from the side of the head, rather than from the top?
Same principle should apply - you may need a longer stop, though.
Thank you
