RB26 head
How to Degree a Cam
Hi has anyone had trouble getting a dial gauge located correctly on the rb26 head buckets I have fitted pon cams and there is just no space to get the probe on the bucket and get a good reading opening and closing fully without constant error i ground down a long probe so its thinner to access but still no good the angle in all wrong as the cam circumference is so large would there be an alternative method or a trick anyone knows
I am having the same issue… is there anyone out there that could help?? 👍
I made and adapter for my dial gauge.
Here's a picture :
mine was essentially the same. little longer.
I used a 1.6mm tungsten I balled up on AC then brought an extension for the dial gauge and attached it to that.
it can be done, but you right. a standard extension is far to fat.
