True top dead centre using a dial gauge indicator
How to Degree a Cam
Hi there as you mention measuring dail gauge when the piston goes down and the dial gauge at 50 thou, travel, so in metric is this 1mm of travel...
the actual distance does not matter it could be 5mm or 13mm as long as it is the same both directions of
rotation
