Fuel only rotary setup with adaptronic e420d
Introduction to Engine Tuning
Hi all. Was hoping to get some help setting up a fuel only trigger for my 12a with an adaptronic e420d. I’m getting the trigger from the negative on the trail igniter using a shielded wire. The signal is very unstable. Is it better to get the signal off the coil instead? Anyone have experience setting this up.
cheers
