knock detection data logger
Introduction to Engine Tuning
Is there a knock detection unit which logs data for analysis after every run ? this is for a bike and we currently use AIM SOLO 2Dl data logger and lap timer for setups, it is made clear to me by plex tuning that data could be exported by can bus or analog 5v but im not sure if the AIM data logger could work with the plex tuning v2 knock monitor. Also i do not have access to a dyno.
Hello, Ned if you are running aftermarket EFI does it not have knock capability? if it does not run an ECU I would seriously consider fitting something like a link monsoon just for the logging knock ability it does not need to be used to control fuel of ignition but it is also there if needed
Regards Ross
Hello Ross,
Well the ecu we are running is a VORTEX x10 on a 2015 ktm 450 which is capable of ignition and fuel changes, the fueling part is covered as I run a lambda controller for AFR.
https://www.vortexcdi.com/model_product.php?product=59&model=185&mp_id=3655
Above is the link where the ecu we use and its contents can be found, would be a great help if you could help me out on this.
Thank you.
