AEM infinity 5 gear table
Launch Control
I have not been able to find clear documentation on the AEM infinity for the gear table used in TC and other functions. Could someone explain how to populate the values in the Gear Table? I know it's some type of formula based on Gear ratio, but it's not clear.
A short worked example would be nice..
Thank you!
Pete
called AEM..
you need to log the Gear ratio channel in the Infinity 5 then adjust the tables to the values displayed in each gear (without overlapping value ranges)..
ie 1st gear 200 - 185 2nd gear 184- 155 3rd 154 - 130 and so on.. each gear gets two columns in the gear table a low and high value.
Pete
