Emtron launch control setting the problem
Launch Control
Hi everyone
I use Emtron subaru sti 07-15 plugin to control my 2009 ej20 sti,I am setting launch control,launch limit requset always OFF,I don't know where to turn it on?
Thank you
I'm not familiar with the Emtron unfortunately so it's hard to be super specific. It looks like you've set up both a clutch switch and a clutch pedal position threshold for enabling and disabling the launch system - Do you in fact have both? You may find that you need to set whatever you're not using to 0% or something similar. I'll assume the help file would define this for you. You also have a TP/PP lockout of 70% so it will never enable until you exceed that, hence the 'TP/PP Lockout' message under the Launch Status.
Hi master
Clutch switch and pedal position are working normally,Throttle position is also normal,When I completely pressed the throttle pedal, 'TP/PP Lockout'Will become green,I think it's probably because of launch limit request, When I tried LC, it showed OFF all the time.
Thank you
