ground base launch control
Launch Control
Hello Andre will the ground speed launch control have a negative effect when doing a burn out .for drag racing aplication.?
If it's been set up right then it should make a burn out very difficult, ways to work around it would be to have the system activated on a switch or have it on a timer so that the launch control doesn't activate unless the vehicle has been stationary for more than 1 second or so.
What system are you using?
