Gt86 OEM ECU LIMITS?
Launch Control
Hi, I reflashed my ecu with ecuteck software for the conversion to flexfuel, in this occasion I added some features like launch control, but ot is not working as expected. The ecu has been programmed by on official master tuner of ecutek. In that case it was not able to do the following:
-Set different rpm limits in function of the speed ( only one is possible)
-enable traction control only during launch
-combine launch with the activation of the clutch release regulator solenoid (driven using the stock output of evaporative purge valve)
After he done this the traction control was everytime enabled and the regulation of it doesn't work, the launch valve was activating everytime the engine goes over 3000rpm and continuous open/close very fast like clikclikclik....and the rpm limit was active only until the clutc has been released...
My question is if it is a software limitation and I need a standalone for this or is the tuner not enought able to program the ecu?
Thank you very much!!!
