rev limit launch control on the kpro4
Launch Control
i'm looking for a setting to make my 2step pops and spit fire on a k20 N/a motor but retard ignition and fuel enrichment i looking some help ?
Unfortunately you'll struggle to get that sort of effect on a N/A engine. The best you'll get is to use an ignition cut limiter with ignition retard however this won't have the same effect that you'll get on a turbo engine.
ok can i find the ignition cut limiter on the kpro4
