Aem 3.5 bar map sensor calibration
Hi, im brand new to tuning and just setting up my first ecu! my current issue is getting my aem 3.5 bar map sensor to calibrate. I have a friend with the same exact set up as me (98 sti plug and play link g4+ and 3.5 map sensor) so ive copied his map sensor settings. I get error current
map <5kpa or >5kpa of baro reading. any ideas?
Sorry for the late reply. This would suggest you MAP calibration is wrong. AEM should be able to provide the specific calibration data for you so I'd email them. Most of the AEM sensors use a generic 0.5V = 0 kPa and 4.5V = max range (350 kPa in this instance).
