Aggressive rpm limit
hello!
Wondering how to tune the rpm limit to deliver aggressive sounds and bangs.
Thank you
You can affect the sound and agressiveness of the rev limit by enabling the advanced mode and changing the limit control range. You will also get a more aggressive rev limit by using an ignition cut rather than a fuel cut however it's important to know that this can damage the valve train in some engines so you need approach this with care. A fuel cut is a much safer limit option but usually won't generate the noise you want.
