Fan wont shut off
I am using the PNP Link ECU G4+ for the EVO 9. When I turn the key to on position the AC fan runs and will not shut off. What do I need to do to adjust that? Is this one of the Aux? Do I look at the Runtime window to trace this down?
I have turned off every aux and the fan is still running!
Are you using the Link base map?
Yes I am
have you seen that one of the spare ignition drives is controlling one of the fans? fan 3.
Hi i have a g4 on an evo 8 260 and got same issue tried loads but still have cooling fans always on!!
on the G4 use the run time values and check to see if your air-con request is on, Press 'r' when connected.
Settings for the air con request are on Digital input 6 (DI6) try switching the pull up resistor on/off
Settings for the air con fan are on Ignition drive 4, try switching the polarity high/low
Let us know how you get on
