Link G4+ Fuel Table Map readings
hello guys...
i got a G4+ with its MAP 4Bar installed but can't seem to see the pressure on the fuel table more than 0.7psi also for ignition table its showing only 14psi.
When you are viewing the table you want to modify, press X on your keyboard to bring up the axis setup screen, then set up the table axes however you like.
Appreciated
