Link G4+ Mixture Map Feature
I had purchased the tutorial and the road tuning course with great success ton of information on how to work with the G4+.
However there is something that I think is not covered which is how to use the Mixture Map which I think is a great tool for tuning.
I read the help file of how to use it but it will be nice to have a video or webinar about it.
Please advise.
You're in luck as we've already covered the mixture map function in this webinar: https://www.hpacademy.com/previous-webinars/041-using-data-logging-to-improve-your-tuning/
One of the best options Link has in their platform.It is mainly made for the driver and not the tuner as the Auto tune future that Link also has.
You have to adjust properly your AFR target table and shut down the Closed Loop Lambda.
Then you just drive,cruise wot etc as much driving conditions you can achieve.
There is a help file and proper posts in the Link forum, check them out.
Thanks for the info.
I will check the webinar and the link forums.
Regards.
