Link G4X install in a Rev 3 3SGTE
Hi, I'm about to install a Link G4X ecu to my celica GT4 next week and was wondering if someone who has some experience with the REV 3 3SGTE knows what dead times I should be using for the stock 540cc injectors and the factory ignition coil?
If anyone had starting points for fuel and ignition maps as a jumping off point that would also be really helpful.
I'm also going to be running methanol injection and will probably install an AEM kit but I would like to do away with AEM controller and use the Link. Does anyone know of a suitable relay that would be happy driving the pump in PWM? I'm assuming the link would be happy driving the coil of that relay directly
hello check the base maps from links G4+ software the info is all there to copy across it will be a little time consuming.
Regards Ross
