RPM RATE
Hello!!
Please can you explain to me the RPM rate ?
RPM is revolutions per minute, so the speed of the crankshaft. Can you give more background to your question?
rpm rate rpm/sec on link g4+ log issue
On a logging the engine rpm is a smooth curve but the rpm rate(RPM/sec) is a spikes. How to tune the rpm rate(RPM/sec) ?
The RPM Rate (engine acceleration) can tell you several things. Is there a traction event (ie, wheel spin), a misfire, or crank trigger error?
