03 WRX from colorado
Member Introductions
Hello. Im Jeff from Colorado. I drive an 03 wrx/08 sti. Ive been tuning my car since 2004 strictly on nemesis ems 2.1, 2.5, 2.7. Ive been experimenting with different setups with the ej20/25 currently on a destroked 2.34 closed deck block.(+2mm manley Htuff+ rods, CP 9.0 piston) Heads are ported 2.5 heads fitted with supertech springs and retainers and GSC super allow +1 exhaust and intake, kelford 282 cams. turb is a Gen 2 GTX35R @35-42 PSI. Since Ive joined I have been able to really delve into the ecu, adding staged fuel pump, water injection on a pwm, But mostly ive used it to help out idle control and cold start/hot start on my ID 1700cc inj. Im glad to be a member
https://img.nasioc.com/image/3i92
https://img.nasioc.com/image/3ICh
https://img.nasioc.com/image/3G0v
https://img.nasioc.com/image/34NO
https://img.nasioc.com/image/y9wI
https://img.nasioc.com/image/3ZU8
https://img.nasioc.com/image/39d4
