Hello from Adelaide
Member Introductions
Hi there,
My name is Jared and I've been into cars as long as I can remember. I learned a lot from my father growing up, who was a qualified Fitter and Machinist. I have always generally done work on my own cars other than things like crash repairs or A/C work, which was not equipped for.
I recently found myself going down the rabbit hole of learning about engine rebuilding when I decided to pull my leaking engine out of my '07 Liberty GT-B, which also needed a clutch. The more I pulled it apart the less satisfied I was with its condition, which has resulted in a complete teardown.
I'm here to firstly learn about all the details of building an engine properly and will also apply this to my other cars: A 1997 Skyline GTS25t and a 1995 Mazda Astina V6.
I've always wanted to delve deeper into the engine building so thing and may start doing some engine work as a sideline to my day job as a Biomedical Engineer. If anything this will just to help fund my personal projects and help others out that are on a budget like myself.
Hope to get to know more of you on here and sink my teeth into some in-depth build work.
Welcome Jared! Thank you for joining us.
Thanks Mike :)
