Hi all Kenny from FL
Member Introductions
Hi all im Kenny and own a 1997 Toyota Tacoma with a 1jz swap, im currently rjnning a R154 gear, 550cc insjectors, Spec 3 Stage 6 puck clutch, lsd rear end, HKS ECV electronic boost controller, Apexi AFC2, Stock 1jzA70 ECU, Single T3 Turbo MP turbo 6262 dual ball bearing, running 18 psi and 410ish whp, upgrading as we speak to 1000cc inj, Megasquirt MS3X ECU, Quantum Fuel Pump 340LHP, rewiring engine bay, new fuel pressure, oil pressure senders.
Bet that truck has got some balls
Welcome!
That's a sweet ute man! Did you build it?
Hi Kenny,
Welcome to HPA, it'd be good to see the difference switching from the piggy back SAFC to a standalone, keep us informed
What has happened to the build?
