Hi from Bay of Islands NZ Chevy 6.0 turbo
Member Introductions
Hi, newish tuner, long time you tube watcher of Hp Academy, have a 6.0 litre LS1 Chevy suburban (just shy of 4 ton) with cheap home built turbo setup running HP tuners, 2 bar os, 42lb flex fuel injectors upgrade, T4 turbo, water to air Intercooler located under bonnet, 44mm external wastegate, build almost done and in line with NZ LVV vehicle compliance regulations, thanks to the courses for giving confidence to undertake home build
hello and welcome to Hp Academy, what a cool project I had a mate that had a 80s GMC suburban 6.2 diesel with barn doors it was such a cool truck to drive
