HI, From Melbourne, Victoria Australia
Member Introductions
Hi,
Allways been interested in efi tuning but never thought i could do it so after a bit of reading i decided why not give it a shot.
I have a few projects mainly boats i have race boat i am building with a Ls1 which has just been built with CNC heads cam new bottom end and tunnel ram set up around 550 HP.
a ski boat with a Ls2 6.0 in it pretty standard but want to go through the tune to learn a bit before tackeling the race boat
and eventually make it to my Vq statesman which when i start building that i want to head down the path of a turbo 355.
looking forward to learning alot along the way.
Cheers
Mat
Hi Mat,
Welcome to HPA. what ECU's are you running in your boats?
Hi Chris,
i am just running the standard GM ecu’s
Hi Matty,
What software are you using to tune them?
Nice one Mat, what size is the boat? Should be a great project to cut your teeth on =)
Hey Chris ill be using the HP Tuners software.
Hey Taz the boat is a Rival hull its a shallow Vee 18'6" V Drive. not sure how to put a picture of the boat up but if I work how too ill get one up.
