fuel pump congfiguration
MoTeC M1 Software Tutorial
hi guys,
i have a motec m130 with gpr package. i have 2 fuel pumps in the car and have both set to run off relays activated with ls ign outputs. i have one pump running off the fuel pump option and another to an aux option. both work but would like to know how to configure both pumps to run non sequential ( at the same time)? thank you
If you want both pumps running in parallel then just trigger both of the relays with the same output.
