Haltach TCA-8 Eight Channel would work with the M1 can
MoTeC M1 Software Tutorial
Hi ,
i am wondering if anyone try to connect the TCA-8 Eight Channel Thermocouple Amplifier with Motec M1 serious, the same way we connect the race grade EGT kit through the CAN?
https://www.haltech.com/product/ht-059918-tca-8/
Thanks
Hey Saud,
If you are using a typical firmware like GPR then the ECU can only receieve EGT from an E888 or RaceGrade TC8.
The CAN stream the ECU recieves EGT sensors on is fixed and is designed to work with the E88, the TC8 just mimics this CAN stream.
If you had a MoTeC dash you could possibly use this to recieve and relay the signals from the haltech unit to the M1
