level one logging rates
MoTeC M1 Software Tutorial
hello,
what are the fixed rates of level one logging? when setting up my data logging i only have 1hz, 2hz, 5hz and 10 hz. is this what level one provides?
thank you
Hi Luke,
That is correct. The Level 1 Logging is a set of diagnostic channels that have been developed to allow for the most typical issues that would be found when getting a engine running with an M1 to be found. These channels can't be removed from a standard package.
The way to tell if they are a diagnostic channel from looking at the logging, is if they have the green icon that i have highlighted in the attached image.
Hi BlackRex,
Thank you.
