M130 Throttle pedal %
MoTeC M1 Software Tutorial
Have a m130 pnp kit for wildcat xx from jrr, I cabt get the Throttle Pedal Sensor % at idle to get below 20, it doesn’t change no matter where I set the voltage. Idle is high. Any helps greatly appreciated
First call should be to JRR as they will know their package. But if you post your package here (go to Open Package in M1 Tune, then "Export to File" to create an archive file, you can put this into a ZIP file, and upload that).
First thing I did is try to call but websites completely different now with no contact info, I filled out the email form 2 days ago but no reply. This am I found inside the ecu his name address phone # I called left a message. Im sure He can probably resolve it in 3 minutes.
What is the actual channel name that is reporting the 20% value?
Initial setup 2
then throttle pedal
shows % at the top
20% at idle 100% full throttle. Ive done the main offset and main scale many times and saved.
