Motec C127 input issue
MoTeC M1 Software Tutorial
I have an issue with trying to setup a oil temp sensor to AV or AT input of C127. Have wired in a Bosch 0 261 230 482 temp and pressure sensor, have also upgraded the C127 with the I/O Upgrade. I have entered the sensor calibration for both pressure and temp, the pressure side of the sensor works. but the display shows on screen 178 deg. (sensor doesn't read that high). The sensor is working correctly as if i take a reading via a multimeter. have also changed the pullup. no luck..
You will need to connect the pressure sensor output to an AV input, and the temperature sensor to an AT input. Looking the the Help Topics->Reference=>Input Characteristics, you will see that the AT inputs have a 1K pullup built in. (so you should not be adding any additional pullup, or when calibrating changing the pullup value to anything other that 1k / 1000 ohm. If you want to upload a copy of your config, we can take a look (might have to put it in a zip file).
Hi Glenn, Did the file that I sent work?
