Racegrade SSD3 configuration with M150?
MoTeC M1 Software Tutorial
I am going to use the Racegrade SSD3 to PWM control my fans.
As I read the instructions I would use a Ignition/EFI B+ for the “Active High” input signal and then use an available LS output from the M150 to send a duty cycle signal to the “Active Low” input.
Has anyone configured one of these and can confirm?
http://www.racegrade.com/downloads/RG_SPEC-0021%20SSD%20-%20Sink%20Source%20Driver.pdf
While I haven't used the product myself, a quick look through the documentation you've linked to would suggest you're correct. I'd just be supplying a 12V switched input to the unit so that the Batt+ is at 12V any time the ECU is running (this seems a little redundant to me), and then you can use any output that is low side switching to PWM control the SSD.
