DZUS Clips
Motorsport Fabrication Fundamentals
I would be appreciated if you could go into more detail on selecting the right size DZUS fastener as well as adjusting the spring (if needed), self ejecting, backing plates and head type selection.
A simple google search for "a guide to DZUS clips" should give you plenty of thought in the meantime.
I had the same comment as Magpie. There are a lot of different options on Dzus mounting plates, spring heights... Yes, I can Google and I did before I bought this class but I thought the class would go into a little more detail, like when to use Dzus over threaded, adjusting spring tension and the like.
