Direction induced
Relevant Module: Practical Skills > Measuring & Adjusting Bump Steer
Hello, is it better to have toe-in on compression to stabilise braking or toe-out on compression?
Thank you for your reply.
Best Regards Yann
It's better to have no toe change or the minimize it -- this is called bump steer.
On braking, front slight out, rear slightly in, is more stable - but, as David said, it's better to have no toe in/out variation through the suspension travel - not least because it makes the front end twitchy over bumps as the steering agle of the wheels moves, and makes setting up the suspension geometry tricky.
