How to measure toe without jacking up 86
Hey everyone. In this video, Andre mentions that you can adjust toe in the 86 without jacking up the car. How is this done? Thank you!
I often adjust front toe with all 4 wheels on the ground. just reach behind the wheel well and adjust the steering tie rod / lock nut as normal. you will need the wheels on turn tables or "slip plates".
