Test Results
Where would I find the set-up sheets?
Hey Lester, if you have access to the Wheel Alignment fundamentals course (which I'm assuming you do) then you can follow this link here...
https://www.racecrafthq.com/assets/Course-content/Wheel-alignment-Fundamentals/698ab26766/Setup-sheet.pdf
We realise it's a little tricky finding the work sheets on the modules, we are working on this!
Matt
I was thinking the other day along the lines of you providing a convenient DLC (Down Loadable Content) links page for things like that set-up sheet, cable sizing, test sheets, quick reference sheets, etc. for members?
I also noticed the other day that, while there is a report option it is applied to one's own post, not other peoples, which is a little strange - one is rather less inclined to report one's self than others - although I haven't seen anything coming anywhere close to needing this - they're all good guys and gals.
