AEM powered up! Thank you!!
Off Topic Discussion
This last weekend was an epic wiring and configuring fest. Thank you HP Academy! Without your help and teachings this would have been much harder! The entire car harness only had two mistakes that were easily corrected, credit to the wire planning section of your wiring fundamentals class!
How about a webinar on AEM infinity ECU 1st time setup/firmware? A little bit of fumbling was had, but eventually reading AEM guides it got sorted.
Thanks again!
Peter Belfanti
#14 Sport Touring 3.5L Honda V6 Mazda miata
Well done, now get some video's up ;)
Hey Peter, great work! If you own the practical dyno tuning course, take a look at the worked examples section as we just added a complete worked example on the Infinity using our 350Z.
I totally just found that infinity section! Thank you! Totally appreciate the platform support!
No problem! I hope it helps you out :)
