diagnostics dual-mass wheel
Off Topic Discussion
Czy znasz jakąś konkretną metodę dobrej diagnozy uszkodzenia masowego koła zamachowego? Dziś zauważyłem drgania silnika, szczególnie podczas rozruchu. Pozdrowienia.
It probably depends on the failure mode, usually the rubber/elastic elements just fail in such a way that you get additional driveline backlash/harsher clutch take up. If there was a bearing failure causing a balance issue it should get worse with increasing engine speed.
If it's on starting it could be an injector or ignition issue as well.
