Kaizen Relay ( No device found )
Off Topic Discussion
Anyone used Kaizen relay ? I just cant get it connected to my PC it says ( No device found ).
Are you using the control module?
More information on the application you're using it for, and how you are trying to switch it would help.
I find out that I need arduino software to control it. I want to give it PWM signal (0 to 100% Duty cycle) from ECU to make it control fuel pump voltage (based on PWM signal).
Yes I do have control module for it.
