Manifold surface temp sensor
Off Topic Discussion
Looking for an NTC sensor to measure intake manifold surface temp. 6mm ring type would be ideal. What's out there?
Something like this:
http://www.carrel-electrade.co.nz/sensor/pdf/pt105-rt.pdf
Thanks David. I wasn't sure that I could use a PT100 type having a resistance that low. I was thinking something more in the 5k or 10k range. MoTeC M800.
You should have mentioned any limitations. You can use this on an AV input with a proper pull-up resistor. You could also look for PT1000 sensors.
I know you said NTC, and PTxxx are positive, but I think you really meant resistive-type sensors.
