Toyota Supra JZA80 2JZ-GTE VVTi Engine
Off Topic Discussion
Hi all!
I have a technical question?
I ordered in Japan a Toyota Supra JZA80 with VVTi engine!
This model I would like to tune!
But there is no plug and play ECU from LINK!
A cable adapter I have not found!
(Only with AEM I found something!
But I do not want to install AEM!)
What could you recommend me, as I can make it best with a LINK control unit?
In advance thank you for your help!
Best regards,
Twintu92
Twintu92,
If you're wanting to run a Link G4+ I would recommend fitting the likes of a wire in Link g4+ Extreme or Fury.
You don't even need to make a full loom, if you get the pin outs you can make an adapter harness or tap into the stock loom.
Also you would need to convert the twin turbos (if still fitted) to parallel as the Link won't control the Sequential setup.
Hello Chris!
Many thanks for your response!
Could I use the LINK ATOM II?
And what functions can I leave to the standard ECU?
And what functions do I have to have the link ECU run?
Best regards,
Twintu92
I would remove the stock ecu completely and use the link ecu.
You can't use the Link Atom as it doesn't do VVTi Control.
I would look at a minimum of the Storm or move onto the Fury or Xtreme.
Thanks for your help Chris!
Best regards,
Twintu 92
