PMU total current output
Relevant Module: Worked Examples > ECUMaster PMU16 Worked Example > Step 1: List System Components & Determine Power Draw
I noted that you propose to make use of 2 off PMU16's in order to have sufficient current capacity for your vehicle. You felt that having an estimated requirement for 148 Amps was too close to the PMU16's maximum of 150 Amps. If you chose to use the PMU16-AS version you get a maximum capacity of 200 Amps which would give you a good safety margin. Is this something you have considered?
That unit may not have been available at the time, but is certainly worth considering today!
