corner weighting
Practical Corner Weighting
Discussion and questions related to the course Practical Corner Weighting
Hello you guys are great Thank you for your sharing of knowledge.. my car is a 97 S14 240sx and my current numbers after adjusting are:
Driverside 822lbs Passenger front 814lbs
26.6% 26.3%
721 lbs rear-drv 736lbs rear pass
23.3% 23.8%
total weight 3093lbs
should I adjust anymore or keep it?
You can get it a little closer, but depending on the use of the vehicle a little difference may actually be an advantage, if it's the 'right' way.
I assume you did it with driver, ~half fuel load, equally worn and pressured tyres, etc?
