In the "Torque to fuel quantity injected conversion" map, where I have RPM on the Y axis, Torque (Nm) on the X axis, and the entire map indicates the fuel dose in mg/hub. However, in the "Injection duration" map, where we have bar on the y axis, mm3/inj x axis, and injection duration "us", if I have the maximum value of 90 mm3/inj and in the "Torque to fuel quantity injected conversion" map I have the fuel dose in mg/hub, what is the conversion factor from mm3/inj to mg/hub so that I can know what maximum dose I can get from these injectors? From what I noticed, only the injector calibration map is in mm3/inj and the rest of the maps are in mg/hub, at least that's how it is in most Damos.
1mm3 ~= .835 mg for diesel fuel
-Nick
Text
