2005 STI Project
Practical Standalone Tuning
Hi all! I am currently working on building my first big tuning project and would like to get some feedback/advice on my thought process as I go through with this. Closed deck longblock EJ257 is being built as we speak, with a lot of goodies by an extremely reputable machine shop in my area well capable of handling my goal of 500-550 WHP on E85. Significant modifications are...
FP Black turbo
ETS Front mount intercooler
ID1700 CC injectors
Fuel System with external surge tank by Aftermarket Industries
AMS Intake manifold
Killer B holy headers
Link plug n play standalone
With the AMS intake manifold installed I cannot run stock side feed injectors for startup, nor can I run the stock intake and MAF with the front mount intercooler setup. I was originally planning on running a hybrid setup utilizing the MAF sensor at idle/cruise switching over to VE fueling at higher load. However, I understand I cannot properly tune MAF scaling or Injector flow scaling without stock injectors or intake installed simultaneously as these two rely on one or the other to be properly scaled first. My thought would be to ignore the MAF sensor altogether and run full time Volumetric Efficiency fueling at this point as it'd be easier. My question... Is it worth it to take it step by step installing modifications so that I can scale MAF/ Injectors properly in order to run the hybrid system, or would you guys run full Volumetric efficiency fueling? This is NOT a daily car, but I will be using it on the street mostly, as well as some track days here and there. I am fairly new to this, just throwing it out there to get some ideas from those who have done this before. Thanks!!!!
I would skip MAF tuning, but if you want to do it as a pure learning exercise you certainly could. Just keep in mind any intake to properly support that horsepower level isn't going to be great for MAF readings.
Thanks Mike! That’s kinda where my head is at. I really just wanted to run the hybrid system as a learning exercise but I think it’d be a lot of extra work that probably wouldn’t be worth it.
Sounds good!
