Practical Wiring Course On Sale — 50% OFF 🎉
Ends in 5 hours, 59 mins and 59 secs
4G63T Fueltech 550 12-1 Trigger Problem
Practical Standalone Tuning
Hello guys I have a eagle talon 4g63t I'm trying to run sequential Ignition I'm using the 12-1 trigger wheel from Kiggly Racing and 1 tooth signal from the cam I having RPM but no spark or Injection while Cranking If I switch to the 1g Original trigger 4 Crank 2 cam and Waste spark The car starts No problem if I try waste Spark with the 12-1 wheel I just have No spark or Injection Sometimes Starts but very Random . Using a Hall sensor that comes with the kit I already Try Another sensor Nothing change I tried a lot different Index angles Nothing. checked The Positive and Ground For the Hall sensor Everything seems to be fine . Thank you in Advance
Title
Text
