EMTRON KV12 Rotary setup
Practical Standalone Tuning
Hello,
I was hoping someone might be able to chime in and double check my engine setup in the KV12 for a Mazda 20B using the FFE Hall sensor and trigger wheel. This is the first ECU I have configured that doesn't have a dedicated "rotary" engine mode. Thank you for the help and any other key points of insight you feel I should know headed in.
Engine type should be set to 2 stroke. Your firing order settings look ok.
Adam,
Thanks mate. I had it as 2 stroke then overthought it and double guessed myself again.
