Injector setup
Practical Standalone Tuning
I have 1150cc bosh injectors they are not in the setup wizard when I click the drop down menu. So I selected the closest size to 1150cc and put the dead times in but noticed that the setup wizard said the deadtimes I put in don't match any of the injectors listed, is this going to be a problem?
What ECU are you using? I'd probably ignore the setup wizard completely and just make a custom injector characterisation to suit. Provided your flow, base pressure and dead time data is correct you're fine.
