Hi. Why during tuning VE cells you just wanted to achieve: real lambda = lambda target?
You've set this lambda target base table in the first steps of steady-state tuning process and never changed anymore. So, how can I know that this lambda target is the best for my engine?
Why did you focused in achieving higher torque just during ignition calibration?
Hope for your answer.
If the VE table is built this way, then you can spend time on the dyno in steady state mode varying the lambda target just to see the effect on torque just like ignition timing. What you will find is that over a 4-5% range, there is really no difference in power, so we just use the targets our experience tells us will work.
But if you have the time and inclination, it's worth testing this to makes sure it's true.
