Turbo speed sensors
Practical Standalone Tuning
Thinking of using a Garrett turbo speed sensor.
1. Is it worth it?
2. In their instructions they vaguely mention the wiring. Am I correct in thinking that my AEM Infinity Series 5 will accommodate it?
3. Do you know what type of sensor it is? Is it VR or hall effect requiring Power, signal and ground pins? I want to allow for this in my harness build.
Thanks!
Norm
The sensor is the same (or very similar) as it has been used on the EFR turbos for a long time and it is hall effect, so you need to supply 5V, GND and a signal wire.
The output is a 0-5V square wave which the infinity should easily be able to use.
Dankeschön
Hehe you're welcome.
Answer to your question 1: yes, absolutely. If I can I put a sensor in every car as it gives you great information as to where the turbo is currently operating. Also you can protect it from overspeeding.
